TwinTurbo.NET: Nissan 300ZX forum - yes, but you're still wrong
aliaZ
on January 11, 2013 at 11:59 AM
higher pressure will always move to low pressure
posted by Red Hawk (CO)
on January 11, 2013 at 01:09 AM
Air will flow out of the crankcase, but fresh air will not flow in because there is no active ventilation. Moisture will condense inside the crankcase rather than be flushed out with active ventilation.
Need some help fellas... Creamy oil
Project_Broke
09:42:06 01/10/13
What does your coolant system look like?
TriniTT
11:49:09 01/10/13
Re: What does your coolant system look like?
Project_Broke
12:18:17 01/10/13
Compression test.
Red Hawk (CO)
14:39:31 01/10/13
BAD to bypass the PCV System
Cjw3
13:42:49 01/10/13
^this (n/m)
Zvil (FL)
13:48:52 01/10/13
I dont think PCV is causing this.
Red Hawk (CO)
14:31:46 01/10/13
I think you're wrong
aliaZ
16:15:07 01/10/13
Red Hawk (CO)
01:09:10 01/11/13
yes, but you're still wrong -
aliaZ
11:59:25 01/11/13
Tell me where this "fresh air" comes from
Red Hawk (CO)
12:30:25 01/11/13
It's the 5/8 Inch lines that hook to the Intake Tubes
Cjw3
15:05:04 01/11/13
fresh air comes from the tubes on the front of the intake
aliaZ
16:53:58 01/11/13
but isnt that air always in vacuum? not to mention metered? (n/m)
10:33:55 01/13/13
it is under a slight vacuum
aliaZ
15:28:23 01/13/13
Hmm.. Sounds good.. but..
Cjw3
16:21:48 01/10/13
I ended up hooking up one of the PCV valves back up
Project_Broke
18:14:43 01/10/13
I run a catch can and no pcv valves with E85 my can catches
scottmt21
19:57:56 01/11/13
